20 Most Recent Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Questions & Answers
If the timer does not rotate, then the clock motor gears have been stripped, or the motor has gotten weak.
With most expensive timers, you can buy and replace the clock motor.
But not with the Malibu power pack.
I tried spraying WD-40 on my timer dial.
And broke the power pack apart looking for ways to disassemble it.
Power packs are one-piece units.
New power packs have electronic clock, so test your circuit with circuit analyzer before assuming new electronic gizmo will work better.
"Harry" wrote in two months ago with a brilliant work-around.
His timer stopped working.
He bought a cheap plug-in timer and then connected power pack to that timer.
Harry also said that his power pack has 5 year warranty.
He was 'negotiating' with malibulights.com over the warranty.
I hope he writes back and says how it went.
Here's the contact page.
http://malibulights.com/customer_service/contact_us.aspx
Here are some tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Another option is to take advantage of fixya phone support.
Fixya expert will walk you through the same information for a price.
Malibu ML200RT -... | Answered on Dec 28, 2018
The usual "fix" is replacement.
Malibu ML200RT -... | Answered on Jan 11, 2018
Clock motor not sold separately
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Malibu ML200RT -... | Answered on Dec 07, 2015
Malibu transformer is 12 volt AC
They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Water Heater Timers Save Money
Malibu ML200RT -... | Answered on Jul 19, 2015
Malibu 120 has photoeye.
At night, the darkness causes photoeye to turn lights ON
Lights located near to the photoeye can cause the photoeye to 'think' it is daytime... so photoeye turns lights OFF...
Then it's dark again because lights are off... so photoeye turns lights ON.
The cycle repeats ON-OFF all night long.
Gene
Malibu ML200RT -... | Answered on Feb 15, 2015
Try power pack on different outlet/ bring around extension cord
Gene
Malibu ML200RT -... | Answered on Oct 17, 2014
Try following information
Gene
h
Malibu ML200RT -... | Answered on Jul 22, 2014
Malibulights.com manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Guide for setting up lights
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
Tips for power pack:
-Match up wattage of bulbs with wattage of power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
Malibu ML200RT -... | Answered on Jul 19, 2013
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
88 questions posted
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
john h
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
need timer pins
  • Hardware & Accessories
