20 Most Recent Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer Questions & Answers
How do i fix a Malibu timer ML121RT to override the unit to use a separate timer?
Mine is a ML121rt. Lights just went dead one day. Took it apart and found a spider egg in the switch and the contacts slightly fouled. The switch comes apart easily. Cleaned it and hit the contacts with a point file. Good as new. Tools needed: Torx bit, voltmeter, point file.
7/26/2019 4:15:04 PM • Malibu... • Answered on Jul 26, 2019
I have LV371T and the clock timer setting is
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Plug into cheap wall timer Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/18/2019 9:30:54 AM • Malibu... • Answered on May 18, 2019
2answers
THE TIMER DOES NOT WORK , NEED TO REPLACE IT WHERE
I've done a lot of reading and research on Malibu
No replacement parts for Power pack, or schematic >> Malibulights.com shows replacement lights and replacement power packs
Manual for Malibu 600 Watt power pack
SAVE the pins off old power pack and see if they match pins on new power pack ... because you can't find pins on the internet
When the power pack goes bad or you lose the pins, then you buy another power pack
Things to remember:
Match number of lights to power pack wattage
30 - 20 Watt bulbs => 30 x 20 = 600 Watt power pack
Replace bulbs as soon as they burn out, or other bulbs will burn out quickly, and I think it causes power pack to burn out sooner too.
Up-vote if this helped. Thanks for the feedback.
11/28/2015 9:10:14 AM • Malibu... • Answered on Nov 28, 2015
2answers
Malibu Lighting Breaker Switch
There are two possible problems you could be facing (excluding the transformer going bad) If you have replaced light bulbs with higher wattage ones, you could be drawing too much current through the transformer. (It is common for MR-16 style lightbulbs to be 20w in landscape lights, but 50w for inside lights, and the local hardware store usually only carries the 50w replacement lamps) Each transformer has a specific amount of "watts" it can supply (anywhere from 100w to 1000w) If you exceed the supply wattage of the transformer, the breaker inside the transformer will trip. The quick and easy way to test this is to take a few of the lightbulbs out and see if the breaker will hold.
If you are positive that the total lamp wattage does not exceed the rating of the transformer the second possible problem (but less likely) is that you have a lamp socket or wire connection that is full of water. This water between the two conductors draws current just like a light bulb and can cause an overcurrent fault. This is usually more common if it starts to trip right after a heavy rain when the ground gets saturated with water.
Good Luck!
4/18/2015 11:23:47 AM • Malibu... • Answered on Apr 18, 2015
Sir:
10/17/2014 3:35:14 AM • Malibu... • Answered on Oct 17, 2014
Timer on my ML121RT transformer quit working.
Timer module not sold separately http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:34:35 AM • Malibu... • Answered on Oct 17, 2014
I have a ML121RT Low
Try it... should work http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install However minimum load for ML121 is 80% load rating.. so 80 watts is ok for 100 watt transformer... 60 watts is low and can cause early failure of transformer. Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:31:27 AM • Malibu... • Answered on Oct 17, 2014
Timer does not work on my malibu light transformer
Plug into cheap wall timer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:25:35 AM • Malibu... • Answered on Oct 17, 2014
Have malibu ml 900 tw transformer that 1 section works and other 2 don't
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot Replace timer Look at 5 year warranty Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:22:45 AM • Malibu... • Answered on Oct 17, 2014
I have a ml121 transformer lights go on but then after a while shut off i noticed that the box is hot
Hot transformer is fire hazard... warmish transformer is normal... replace transformer http://waterheatertimer.org/Malibu-power-pack-stopped-working.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:12:41 AM • Malibu... • Answered on Oct 17, 2014
Warranties manuals
10/17/2014 3:07:14 AM • Malibu... • Answered on Oct 17, 2014
How to set the timer for the brinkmann timer
http://waterheatertimer.org/How-to-set-timers.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/17/2014 3:02:10 AM • Malibu... • Answered on Oct 17, 2014
Malibu Timer manual
10/17/2014 3:01:27 AM • Malibu... • Answered on Oct 17, 2014
Lights blink on and off when I plug them why?
10/17/2014 2:56:27 AM • Malibu... • Answered on Oct 17, 2014
How to reset
10/17/2014 2:52:02 AM • Malibu... • Answered on Oct 17, 2014
Malibu model noml121
10/17/2014 2:51:21 AM • Malibu... • Answered on Oct 17, 2014
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
69 questions posted
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Malibu Hardware & Accessories
Most Popular Question
7 20w bulbs newly wired line running
  • Hardware & Accessories
