When switched to gas, the igniter on my caravan fridge does not light the gas. Have to manually remove cover outside and then use a butane gas igniter to light gas.
SOURCE: Motorcaravan fridge auto-igniter continues to
Yes the problem has been solved by cleaning jet and repositioning thermo-couple so that it is well into the flame.It would therefore appear that the combination of a partially blocked gas jet and a badly aligned thermo-couple triggered the auto-igniter .
Thanks for your interest,.......I am afraid that at my age now help has to come free of charge.A new auto-igniter would have been £69 and a thermo-couple £35.A new jet was a reasonable £6...........
Regards Iain edwards [email protected]
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
SOURCE: 98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
SOURCE: I NEED A USER MANUAL
Hello, here is the manual: -
http://web.me.com/danperkinsartwork/Autohomes-Bedouin/Manuals_files/Electrolux%20RM2260%20operating%20and%20instalation%20instructions.pdf
Also found this site with a list of parts for the fridge you mentioned
http://www.leisureshopdirect.com/Caravan/ventilation/Dometic_Caravan_Fridge_Spares/Dometic_RM2260_Fridge_Spare_Parts.aspx
Hope this helps, good luck
