The unit works on Auto (110) just fine - perhaps too cold but will not ignite on gas setting. Cleaned burner region - no soot or corrosion. Gas is getting to burner but no spark seen. Check light always comes on after 45 seconds. Burner will light manually with match and fridge cools down well but I know without a normal sparking burner the fridge will not work properly. How do I determine if it is the igniter or the black box that is the problem?
frustrated
Qtermile
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
