SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
SOURCE: miele w435 soft-tronic check drain check inlet
Hi - Try this empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check & assemble - try & see if it will work.
Cheers
