20 Most Recent Miele W2240 Front Load Washer Questions & Answers
Hi, it's caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie. Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work. You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics
Miele W2240... • Answered on Jan 18, 2018
Miele W2240 Front Load Washer leaking This video will show you how to find the leak on your washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Miele W2240... • Answered on Aug 05, 2013
I have a Miele W502.Both lights flashing usually is caused by a water leak into the case of the machine which trips the float switch in the base. You can reset this by tipping the machine forwards at 45 degrees and allowing the water to drain out on to the floor. It will reset everything but if you still have a leak it will trip ou again due to the float switch. I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above. On further investigation I found that the door seal had rubbed on itself at the 6 o'clock position and had worn a small hole which was causing the water leak.To replace or repair the Door Seal you will need to remove the front panel.1. Turn power off and unplug machine after opening door.2. Remove the front panel lower kick plate by inserting a thin ruler between the kick plate and front panel about 4 inches from each end and lever down until it releases.3. Remove the 2 screws at the door lock switch on the front panel.4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.5. Remove the spring loaded band from around the edge of the door seal facing you and after that release the seal from the front panel and push in.6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.7. You should now be able to lower the front panel out of the locating pins and remove it.8. With front panel removed you will be able to remove the tensioning band which holds the door seal in place around the drum by undoing the screw at the right hand side of the band at the 3 o'clock position. It is accessible from above with a long bladed screwdriver. Take note of how far it is tensioned on the thread of the screw and try not to undo it all the way or you may lose the nut on the band.9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.10. When you replace the seal do not do the tensioning band up too tightly or you will hear it squeak when you spin the drum in either direction.11.Reassembly is the reverse of removal, taking care to put the door manual release strap through the inner slot in the front panel.I repaired my door seal with Silicone Sealant and loose weave fabric tape after rubbing it clean with alcohol as i didn't want to pay $100 for a new seal from Miele.3_13_2013_1_40_54_am.jpg
Miele W2240... • Answered on Mar 13, 2013
Miele W2240 Front Load Washer Logo
47 questions posted
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Miele Washing Machines
Most Popular Question
remove main front panel
  • Washing Machines
