Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Hi icatci, I tried this yesterday. Water volume on prewash was around 1/2 inch higher than on wash. Tried on both cold and hot with same results. Now the interesting thing. When empty, the red light doesn't flash during rinse fill. And the water volume is the same as on wash. I'll try with loaded washer today, but then I will not be able to see the water level.
Hi icatci,
