After spending much time with the same kind of problem on my all in one printer scanner or I found it to be more cost-effective and less stressful to just replace it. I found another one on eBay for a relatively decent price.
First off all connection unplug printer power and USB cable. Some time wait and replug power first then wait any error show or not, if ok then USB cable connect. If same error show then i suggest you printer driver uninstalled and restart printer and PC. Some time wait and start both device and check it virus and removed it then you new fresh printer driver installed it. If you problem solved then ok, otherwise same issue USB cable so change USB cable.
I share a informative links please read it...
Print cartridge alignment failed Error Message Displays on the All in...
Thanks,
HP Phone Number
SOURCE: HP Officejet 6110 scanner carridge appears stuck
Unplug the power. Plug back in, while simultaneously holding hash (#) and (6) buttons, until S-reset is displayed (sometimes this can take like forever) but it is a documented HP mode.... Then set up machine using 1 key to confirm options and arrow keys to select options.
To enter another maintenance mode (fat lot of good that will do you), press and hold * and #, then press 1 and then 2 and then 3 (or 5) for a variety of different options, which include testing of the scan bed. This of course only works once the scan bed has initialised...
Or: take out all cartridges and close doors. Wait until it complains, or indicates a cartridge jam.
Regards
All-knowing.
SOURCE: Printer shows Carriage Jam, but I can't find it.
Push cartri9age to left about a 1/4", with finger pressure. Un-jammed my printer.
SOURCE: scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
SOURCE: hp psc 2310 is "stuck"
This has been solved in the fixyourownprinter.com forum. Clean the bottom of the scanner glass. You have to take a bit of it apart but it's not hard with the help of this HP site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&cc=us&lc=en&dlc=en&product=303753&dlc=en&lang=en
Good luck.
SOURCE: My Printer Is Printing Wonky Why?
IC
Clean the paper rollers
Follow these steps to clean the paper rollers.
Follow the steps on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02063&cc=us&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
