Frigidaire model ffu2065fw1 the alarm is going off and the control module is blank so I can not adjust any temp. tried reseating module and I do have power going to module is it bad?
Good Morning Friend,
I understand that the light and alarm are working fine on your Frigidaire freezer, model# FFU2065FW1. I also see that you are receiving power to the control module, however it is blank. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try adjusting the temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
SOURCE: my freezer temp.warning light has come on and wont cool anymore.
freezer temp light stays on
SOURCE: Temperature alarm is on on
i would make sure that the coils are all clean, inside and out. make sure the fan runs on the back, the water pan isn't over flowing.
SOURCE: Frigidaire freezer FFU21F5Hwg not running although electronic panel displays normal temp setting
Does the compressor kick on?
Testimonial: "The technican very quickly diagnosed the problem after receiving an answer to his request for additional information following our original posting. Very impressive............ Thank you."
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Hi michael, thank you for your post!
I understand that you are having a challenge with your Frigidaire freezer's alarm continuously going off. From what you are describing it could be a possible problem with your control panel or sensor. Typically the alarm will go off when the freezer senses a high temperature inside, I would recommend having a professional come out to properly diagnosis your appliance and repair it to avoid any unnecessary part purchases. -Matt
