Freezers Logo
A
Anonymous Posted on Jul 30, 2012
Frigidaire freezer alarm
Alarm is going off and temperature is at 34f
  • Official Brand Answer 4,342 Answers
  • Posted on Jul 30, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466541
Points
5907
What is the model and what temperature have you set the unit for before?
4 Related Answers
Anonymous
  • 447 Answers
  • Posted on Dec 27, 2007
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Anonymous
  • 1489 Answers
  • Posted on May 12, 2009
SOURCE: The door of the freezer was left ajar. Alarm light is on and the inside temperature is now about 10 degrees. At what temperature will the red light go out or do I have to reset it in some manner? Than
Thanks for the update. Can we get a "problem solved" rating -- I believe there are icons at the bottom of the screen.
thanks..
Charlie
Anonymous
  • Posted on Mar 22, 2010
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Anonymous
  • 121 Answers
  • Posted on Jun 25, 2010
SOURCE: Temperature alarm is on on
i would make sure that the coils are all clean, inside and out. make sure the fan runs on the back, the water pan isn't over flowing.
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Alarm go on with no apparent reason
Thank you for your post, michael!
I see that the alarm inside your Frigidaire freezer continues to beep it sounds like a potential issue within your control panel or thermistor. Your alarm will beep to inform you that the inside of your freezer is reaching high temperatures. Performing a reset on your appliance could help correct the problem, to perform a reset you need to unplug your freezer or flip the household circuit breaker off for ten minutes. I hope this has been helpful. -Matt
The alarm keep going on with no reason on my frigidaire ultrafreeze
Hi michael, thank you for your post!
I understand that you are having a challenge with your Frigidaire freezer's alarm continuously going off. From what you are describing it could be a possible problem with your control panel or sensor. Typically the alarm will go off when the freezer senses a high temperature inside, I would recommend having a professional come out to properly diagnosis your appliance and repair it to avoid any unnecessary part purchases. -Matt
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
The temperature alarm is going off model no. GLFC2528FW4
I understand that the temperature alarm is going off, on your Frigidaire freezer, model# GLFC2528FW4. To deactivate the alarm, you will press the "Alarm Off" button. If the alarm continues to go off, make sure that everything is staying frozen inside of your freezer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire freezer temperature alarm on but freezer is working
Good Afternoon Friend, this is Z. Thank you for your inquiry!
When your refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the alarm, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging your refrigerator or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your refrigerator. If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
4helpful
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
1helpful
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
4helpful
2answers
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
