Question about Frigidaire Freezers
Frigidaire freezer has H1 error and is beeping and will not freeze
Posted by Capers Smith on
Chris Walker
    Top Expert:
  • Frigidaire Master
  • 1,551 Answers
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Posted on Mar 29, 2019
2 Related Answers
shaxaman
  • 13 Answers
SOURCE: upright freezer - bottom freezes, top won't
check the drain system may have got blocked....
Posted on Aug 10, 2009
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: fridgeaire error code H1
    Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
    Posted on Oct 17, 2012
    My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
    Hey friend, thanks for your inquiry!
    Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
    If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
    Power surge on ffu2065fw2 , what wil it do
    Hello friend, thanks for your post!
    I see that your Frigidaire freezer had a power surge and you're asking what could happen. If your appliance had a power surge it could cause an issue within the board or wiring harnesses. Is your appliance giving any error code or beeping? If so, could you advise what it currently is doing? I look forward to providing you any assistance. -Matt
    Door ajar light is on
    your freeze caused some technical problem,you read your freeze catalouge and there must be get solution.
    Red light showing high tempature
    cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
    My deep freezer wont freeze..it keeps beeping..what do i look for to find out how to fix it??
    Hi monilvsjay - Typically when the freezer is beeping it indicates a warning of a possible malfunction or an unsafe temperature inside. The silence the buzzer, press the ALARM OFF button, however if you have already done so try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. The freezer could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
    My frigidaire freezer upright has an error message door ajar
    Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
    Only cool air and the food will not freeze.
    I'm having the same problem. What do you recommend?
    1helpful
    FFU20FC6AW4
    you said the coil was freezing up? have you checked your defrost element? if your handy with a voltmeter put it on the "beeping mode" (disconnect the fridge's power first) and test the element if it beeps its good, and means that the defrost control isn't working it could be a timer or a board, also check the freezer fan rotate the blades if it dosen't rotate the fan is stuck. if the fans turns out o.k, the defrost thermostat is defective (thats the little metal ball type control befor the heaters).
    1helpful
    Freezer not freezing
    sounds like a leak in the system if under 5 years call frigidaire if not get a whirlpool
    Freezers Logo
    Top Frigidaire Freezers Experts
    Dan Webster
    Dan Webster
    Dennis Boxerman
    Michael Thomas
    Michael Thomas
    Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
