20 Most Recent Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17FK1CW Questions & Answers
thank you for rating.......
in the manual they do not include the various major do`s and dont`s
this is my sole expericence....its true , if the freezer is turned off for many days ....the oil inside compressor gets solidified
Frigidaire 16.7... | Answered on Feb 29, 2008
unplug it for 24 hrs.
Frigidaire 16.7... | Answered on Jan 13, 2008
it sounds like the door has twisted hold the top of the door with your hand and push the bottom of the door out or in and that should fix it you can also put some vasline on the face of the door gasket to help it seal better
Frigidaire 16.7... | Answered on Dec 23, 2007
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Freezers expel warm air. There should be no 'blowing' inside. If it is expelling warm air, then it is working fine, eventually the expelled air should get cooler and cooler.
Frigidaire... | Answered on Jun 06, 2019
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered on May 20, 2019
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17FK1CW Logo
4 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
left door open
  • Freezers
