Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Error code 0F
Model 106gz25fsrxyy
Posted by stephanie garcia on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Posted on Jan 20, 2015
Kenmore upright freezer model 31205 .Needs a new evap fan motor.Sears parts says model doesnt come up cant help.
Recheck the model number on the fridge or try the Manufacturer web sites. A lot of fridges share the same parts, you should find a Kenmore model that is listed with the same part.
Nov 20, 2016 | Kenmore Freezers
How do I get a new key for my old upright freezer?
Would that be the Kenmore 19.6 cu.ft. freezer Model 31205 from about 1981? Kenmore is a Sears product so you might want to check with them if your need service.
Nov 29, 2014 | Freezers
Infrared reciever ice control
What is your question and model number? Is this a refrigerator that you need information about the infrared reciever? I have Whirlpool Electronic Infrared service information just not sure of your question or model number. Thanks, Sea Breeze
Model Numbers can be found in these locations
Dec 13, 2012 | Whirlpool Freezers
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
Need a door gasket for a 1969 coldspot chest freezer dont know model no
On all refrigerators there is an identification tag that gives the model number. Without the model number you won't be able to find the correct door gasket.
Tips for finding your unique model number
  • Look for your model sticker, tag or plate.
  • Include every digit in the model number, even if some are sized or styled differently.
  • Kenmore and Craftsman model numbers typically have three digits separated by a period.
Examples:
Jul 03, 2011 | General Freezers
I am looking for the specifications like cubic footage on my chest freezer
The model number indicates the cubic footage of the freezer.
Example...model number xyz186xxww.,would be 18 cubic feet.
Post your model number on this thread for an exact conversion.
Sep 18, 2010 | Freezers
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
4,219 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
