Ch-07 Splits = Compressor Over Current or discharge pipe temp high. Reasons: LC condenser block-Clean it. Less rpm of fan motor.-Replace capacitor. Discharge temp sensor defective -Replace it.
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Look for snowy frost build up on the inside rear freezer panel. If there is snow, your self defrost system is not working. 90% chance your defrost heaters are burned out (will sow open with multimeter set for continuity, Rx10, Rx100, etc...) If the heater is good check the defrost termination thermostat at the top of the evaporator (cooling coil) it is clipped to the top. About the size of 15 quarters stacked up.. two wires coming out of it. It will only show closed if it is below around 20 degrees. If neither of them is bad, replace the defrost timer. It is in the top of the fresh food section by the control dials.
