20 Most Recent Canon imageRUNNER 2520 Laser Multifunction Printer Questions & Answers
4answers
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format. The page is here and carries all the error codes Error Codes Canon iR2520 Hope this is helpful, if so would you please register that with Fixya Cheers
11/25/2021 4:18:27 PM • Canon... • Answered on Nov 25, 2021
Canon ir 2520 hang or display sowing canon
hi. maybe there is a problem with the system booting section . try to perform a firmware upgrade
8/21/2021 1:36:40 AM • Canon... • Answered on Aug 21, 2021
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
11/27/2019 9:42:14 AM • Canon... • Answered on Nov 27, 2019
How do I fix my Canon imagerunner iR2520 power problem?
Try to remove and reinstall the dimm board located in the main controller board . You can wash all the board but with an adequate liquid ( never use water, soap or alcohol) and use a hair dryer after washing the board it must be completely dry before powering up the copier
10/28/2019 2:02:21 PM • Canon... • Answered on Oct 28, 2019
GIVE THE MASSAGE ERROR E000000 XEROX CANON IMAGERUNNER 2520 MACHINE
Hello, Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. If this does not fix it check connection of the Connectors (Thermistor Connector and AC Connector). If this does not fix it replace the Fixing Main Thermistor (Film Unit). If this does not fix it replace the Fixing Assembly. If this does not fix it replace the DC Controller PCB Best regards, Marius P.S. if you are not in US the part number for EU region is FM4-8445-000
9/8/2017 11:11:52 AM • Canon... • Answered on Sep 08, 2017
Want to clear error code on ir 2520
Hello, Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. Best regards, Marius
12/3/2016 6:59:32 PM • Canon... • Answered on Dec 03, 2016
I have a canon PIXMA 2520 (?) I lost the user manual , I'm trying to connect with my Acer Chromebook 15 laptop , but it's not working , and everything is hooked up correctly . HELP ME PLEASE !
Go to the Canon factory support site and see if they have the driver software you need to do this.
10/17/2016 11:04:48 PM • Canon... • Answered on Oct 17, 2016
My canon 2520 wont print
Is there an error code?
9/24/2016 12:03:18 AM • Canon... • Answered on Sep 24, 2016
0answers
Canon imageRUNNER 2520 Laser Multifunction Printer Logo
83 questions posted
old marine
old marine
Ekse
View Most Popular
S Canon
  • S Canon
Most Popular Question
error code e000020 canon ir2520 turn
  • Office Equipment & Supplies
