You need to elaborate a little more on this.
Is it not coming out of the nozzles? Is it ground coffee going to the drip tray? Is it brewed coffee going to the drip tray?
The brew units on these have been a known issue. If it is broken or failed, I could see brewed coffee going to the drip tray and not coming out of the nozzles.
If you are still getting a proper coffee out of the nozzles, and your drip tray water is brown like coffee - have no worries.
Coffee or clear hot water?
SOURCE: My Miele CVA 2660 built
Hi Robin,
I had this problem a year ago. Two things to check:
1. Does the water tank go all the way down so that the small notch at the back of the tank fits into the floor of the machine?
2. Any dirt at the water tank outlet?
Besides these two issues, I would say that it is very likely that the problem is that the valve of the water tank needs to be replaced. This will especially happen if the machine has been lefter without water in the tank for some time.
Good luck.
