20 Most Recent Keurig Elite B40 Coffee Maker Questions & Answers
2answers
My keurig descale light comes
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
9/16/2022 7:21:30 PM • Keurig Elite B40... • Answered on Sep 16, 2022
2answers
All the lights are blinking on my keurig coffee
the lights on my keurig are blinking and will not turn off. What does this mean
9/6/2022 8:58:34 PM • Keurig Elite B40... • Answered on Sep 06, 2022
5answers
After a few months use there is a green algae like
Using filter water of course helps keep things clean and so forth. To help solve this algae problem when you descale and clean machine use vinegar and that should help from algae building up. Thanks Mike
1/1/2022 3:55:50 PM • Keurig Elite B40... • Answered on Jan 01, 2022
12answers
My Keurig Brewer is flashing the add water,
Perhaps more than one problem people are dealing with but here's what I found. The round float in the tank is magnetic so it's either activating some crappy mechanical switch or more likely a hall effect sensor. Remove the tank and dump the water so the float will rise from the bottom when you refill it. Take a good strong magnet and slide it around the side of the unit where the float would be, tapping it as you go. Put the tank back on and fill it. One try and I was back to making coffee.
12/27/2021 1:39:03 AM • Keurig Elite B40... • Answered on Dec 27, 2021
2answers
Keurig makes clicking sound but will not brew
The exit tube is clogged. Get a paper clip and straighten one end, pushing it up into the tube to clear the material out. The tube is the upper Pin Like projection that pierces the Kcup.
12/7/2021 2:33:14 PM • Keurig Elite B40... • Answered on Dec 07, 2021
3answers
I need a new replacement k-cup portion pack and filter assembly
replacement parts are hard to come by but the portion unit can be bought on amazon.
My filter was metal, so I'm not sure about something cracking...
ebay has many people selling broken units... good for parts... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
3/16/2021 2:27:16 AM • Keurig Elite B40... • Answered on Mar 16, 2021
7answers
Broke my K cup holder, searched for replacement to no avail. Where can i find one?
www.ilikenew.com sells the replacement parts
3/16/2021 2:22:35 AM • Keurig Elite B40... • Answered on Mar 16, 2021
Keurig stopped taking in enough water to make a
heatman101
1/26/2021 8:51:39 AM • Keurig Elite B40... • Answered on Jan 26, 2021
Is there an auto off feature on keurig k-elite? It allowed us to set it to come on in the morning, yet not to shut off at night.
the best thing to do it put it on a smart plug, Cost about $15 now-days. you can program the on and off time as well as shut it on and off remotely.
9/28/2019 4:41:44 PM • Keurig Elite B40... • Answered on Sep 28, 2019
Machine shuts down when brew button is pressed.
I pulled the plug cleaned the machine thoroughly and it is back to normal. Right now i'm in contact with Keurig for a replacement part that is broken.
1/4/2019 3:49:50 AM • Keurig Elite B40... • Answered on Jan 04, 2019
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
4/28/2018 4:19:40 PM • Keurig Elite B40... • Answered on Apr 28, 2018
My Keurig has stopped working. When I turn on
try descaling it sound light its full of scale
12/17/2017 11:47:41 PM • Keurig Elite B40... • Answered on Dec 17, 2017
Keurig Elite B40 Coffee Maker will not make
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
10/11/2017 12:59:25 PM • Keurig Elite B40... • Answered on Oct 11, 2017
My coffee filter for my Keurig, seems to overflow.
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
9/9/2017 5:22:21 PM • Keurig Elite B40... • Answered on Sep 09, 2017
Keurig Elite B40 Coffee Maker Logo
1,057 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Steve
David Shaub
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
all lights flashing will not reset after
  • Coffee Makers & Espresso Machines
