The screen is small vertically no way to make it bigger to view correctly, audio is good. Any assistance would be helpful.
SOURCE: Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
SOURCE: toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
SOURCE: Toshiba Cinema Series MODEL 50HDX82
Hi
Replace the capacitors(about 10 of them) on the Hyperboard 23148024. This should solve the problem. You can confirm this by heating this PCB when cold to prove that it is causing the problem. The fault will dissappear if you heat the parts that are causing your symptom.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
are still unsure, or have problems, then before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
SOURCE: 5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
SOURCE: wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
It's the hyper mod board. I've replaced many of these.
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
