The front tire axels are too short. When I assemble them the metal doesn't come up nearly high enough to hammer on the cap to hold it in place. Has anyone else experienced this and how do I fix it? Thanks!
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
SOURCE: Can't assemble the front tires on the little tikes deluxe cozy.
lube the bead of the tire{ that is the part that makes contact with the rim} with plenty of dish soap for easier installation. place the tire on a angle on the rim so their is a gap where you can put a long flat pry bar in between the rim and the tire with the bar resting on the rubber so that it will not move. then take a second pry bar and insert it in between the rubber and the rim and lifting the rubber slide it over the rim at about 4 to 6 inches at the most place you foot or knee were the pry bar is and repeat that process until you have the tire on the rim. then inflate to recommended pressure.
SOURCE: what screws go on the steering wheel for the
None. You take the white Y bracket and slide it up inside the steering wheel. Let the tips of the Y pop out of the second holes from the bottom. There will be about 3/4 of an inch of the bottom of the Y sticking out of the bottom of the steering wheel. Then, take the white ring and hold it over the edge of the steering wheel exit hole under the dash. Slide the steering wheel post through the hole in the top of the dash and guide it through the exit underneath. Now, there is another hole, at the same angle, a few inches away, on the inside front of the car, that the post should continue through. Keep pushing the steering wheel in until the wheel is flush with the dash. There will be several clicks as it snaps into place. No screws are needed. Good luck.
SOURCE: the front pillars of the cozy coupe don't fit
Ok after three hours I figured it out.
Once you have the hook in the position and all that is left is to apply pressure to press it in. Instead of using your hand like the directions and the instructional video shows. You have to put your foot in the back of the body and put your knee against where you hand is suppose to push and push using your knee with your foot in the back of the body as support. This whole body force snaps it in.
SOURCE: I put the front wheels
Wedge something like a screwdriver under the cap and twist. They usually pop off with a little help.
Otherwise pliers from the top while rocking back and forth may work.
