Screen keeps freezing/jamming and you cannot move back or forwards. If you select menu, touch "navigate", it selects an option of its own which it wont move out of.
If you switch off for a while and then turn back on, it returns to the same screen and your jammed again. Also, resetting takes you back to menu screen but when touching the preferred option, it goes to something different. Its currently directing me to the nearest police station in Bray (Wicklow) and the screen wont budge. Its fully charged and all updates loaded.
Tom Tom are currently looking at my 510 device which is also having problems but of a different type. Am I just unlucky or are these machines just crap!
Bill
TOM TOM ONE STAYS AT THE SAME SCREEN FREEZES WILL NOT GO TO DIFFERENT DESTINATIONSTOM TOM ONE STAYS AT THE SAME SCREEN FREEZES WILL NOT GO TO DIFFERENT DESTINATIONS
You can't post conmments that contain an email address.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
Try this steps:
From a Home screen, navigate: Apps > My Files.
Select an option (e.g., images, Audio, etc.).
Tap the Menu icon (upper-right).
Tap Select then select (check) the desired file(s).
Tap the Menu icon.
Tap Move.
Tap SD / Memory Card.
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Turn it on.
Press menu button (bottom right beside monitor)
on the Drive menu, press right arrow (on the navigational arrows - top right) to move to selections.
Move down four options - the one with "the little clock (pointing to 11pm) and a radio".
Press o.k. (the button with the green key underneath)
That should now show the clock as the selected option on the drive option.
Press menu one final time to exit.
Camera is now in timer mode until you reset back.
To reset back > press menu - at drive menu - select the top option (looks like a single page image) - press o.k. - press menu
How to perform a hard reset. Important: If you are using a microSD card with the Treo. From the Home screen , press Start (left softkey). Select the More option (left softkey). Using the 5-way navigator , navigate to Settings and select with the centre button .Select 'More...' and choose the Security option. Select Encryption.Please make sure the option 'Encrypt files placed on storage cards' isUNCHECKED, select Done (left softkey). Press the Home button. Itwill not be possible after the hard reset to read the data on themicroSD card if this option is checked prior to performing the hardreset.
If charging, disconnect your smartphone from its charger.
Synchronisethe device with the computer so that the smartphone applications andinformation can be restored by synchronising again after the hard resethas been performed.
Holding your device screen side down, use two or more fingers to press against the battery door release to release it.
Remove and reinsert the battery, replace the battery cover.
While pressing and holding end , press and hold power , until the screen wakes up.
When you see "Erase all data?". Press up to confirm the hard reset using the 5-way navigator .
Click on Start, All Programs and click HP My Display, Again Click HP My Display and than you can follow the on screen display to reset it.
Also you can use the front panel buttons
Power Turns the monitor on and to standby or sleep mode. ? NOTE: The power button is located on the top or front of the monitor depending on the model. - Menu Opens, selects, or exits the OSD menu. -Adjusts the volume level. -Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text. – Navigates backward through the OSD menu and decreases adjustment levels. + Navigates forward through the OSD menu and increases adjustment levels. Auto Auto-adjusts the display Select Enters the selected option.
To get your TomTom to speak street names, you will need to change the voice from a recorded voice to a computer voice. This can be done by:
Connect your TomTom to your computer
When the TomTom asks do you want to connect to the computer, choose Yes
Open the TomTom Home application
Click on the 'Add Traffic, Voices, Safety Cameras, etc.' button
Click on the 'Voices' button
Click on the 'Computer Voices' button
You can now select a voice to install on the device.
Once you have installed a voice, change it by
Disconnect the TomTom from your computer
Turn on the TomTom
Touch the screen to bring up the menu
Touch 'Change Preferences'
Touch 'Voice Preferences'
Touch 'Change Voice'
Use the Left / Right arrows to navigate to the voice you just installed (Look for the word 'computer' in the upper right corner by the male/female option)
okay turn on your tom tom then touch he screen so the navigation menu comes up click change preferences then push the arrow key until the screen comes up with change language then select the language
