There is no fluids in either brake on on these,there is two braking systems,both electronically operated .when stopping or slowing up power generated in motor is returned to the battery .this rapidly retards the motor dynamically braking the scooter,a fraction of a second after stopping the electric parking brake is applied by removing its 24volt supply,this is the click you hear when starting or after stopping the scooter.the only servicing reqd is to dust of the casing of the electromagnetic parking brake. do not dismantle it,or oil it.to test try to push scooter,if it moves easily when NOT in freewheel.replace it.
SOURCE: sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
SOURCE: when turning on the charger for a bec sterling 3
what the charger is showing that ?, it has a digital display ? please supply more information
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Testimonial: "thanks for the answer so quick il phone them tomorrow"
SOURCE: info neede for mobility scooter
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
Thank you very much for your help. Andy:)
Thank you very much for your help. I have been eliminating problems one by one. Andrew.
