In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
Replacement cords for many counter top appliances can be found at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Bring the cooker with you to make sure you are getting the correct cord.
Hi .. you can find replacement cords for most counter top appliances at electrical, appliance, and building supply stores. Try Ace, Home Depot, Lowes. Take the unit with you to make certain you are getting the correct replacement cord .
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the corect cord.
