20 Most Recent Frymaster Dean FM345EETC Deep Fryer Questions & Answers
The gas valve may be leaking gas out where it should not be leaking gas out. You may need a new gas valve. This could be a safety issue, not just with a fire, but a potential fire gas explosion. Please get it fixed ASAP.
Frymaster Dean... • Answered on Aug 29, 2015
There is a problem in the system. The problem is usually a sensor that is not reading correctly or not working right.
To troubleshoot this type of problem it is best to call the factory tech. support people and have them walk you through the troubleshooting. then they can also guide you to getting the proper replacement parts. For a problem that is showing up like that you will need OEM parts anyway.
heatman101
Frymaster Dean... • Answered on Dec 09, 2010
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
Frymaster Dean... • Answered on Aug 17, 2010
first thing I would check is to make sure the quick disconect on the gas hose is fully connected,and that the cut off valve is tured on.Sometimes the orifice in the pikot assembly can become stopped up.(where you light it by the burner)you can check there by undoing the gas line at the compression nut on the assembly.the hole is really small and you can use a small needle to clear it.
Frymaster Dean... • Answered on Mar 30, 2009
Check your transformer and make sure that it is tapped for 110v
Frymaster Dean... • Answered on Jul 24, 2008
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Frymaster Dean... • Answered on Jul 16, 2008
Defective thermocouple. It is the metal tube that is in the flame of the pilot light.
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
Here's a link that may help,find your model and click on it,k. http://www.frymaster.com/minisite/service/manuals
Frymaster Dean... • Answered on Aug 04, 2015
This might be due to a loose wire in the light that or it is going out.
Frymaster Dean... • Answered on Feb 17, 2015
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Frymaster Dean... • Answered on Jan 27, 2015
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
Frymaster Dean... • Answered on Jul 30, 2014
Frymaster Dean FM345EETC Deep Fryer Logo
8 questions posted
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Frymaster Dean Kitchen Appliances - Others
Most Popular Question
frymaster pilot not lighting
  • Kitchen Appliances - Others
