20 Most Recent Frymaster Dean H22 Deep Fryer Questions & Answers
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Frymaster Dean... • Answered on Apr 19, 2012
There should be some kind of spark sensor usually where the gas line plugs into the pot. There is one wire hooked to it take the sensor out and clean it good. Soot could be building up on it causing it to nolonger sense a flame.
I would contact Frymaster at 1-800-551-8633. Ask for tech support.
Frymaster Dean... • Answered on Feb 24, 2010
Hi, As per our session, No. The sounders are probably bad or may have been hooked up backwards upon reassembly. GCS in KC would be the ones to contact for parts. Thanks for your business. If I can be of any more assistance, let me know. kstfas
Frymaster Dean... • Answered on Aug 28, 2007
Defective thermocouple. It is the metal tube that is in the flame of the pilot light.
Frymaster Dean... • Answered on Aug 29, 2015
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
Here's a link that may help,find your model and click on it,k. http://www.frymaster.com/minisite/service/manuals
Frymaster Dean... • Answered on Aug 04, 2015
This might be due to a loose wire in the light that or it is going out.
Frymaster Dean... • Answered on Feb 17, 2015
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Frymaster Dean... • Answered on Jan 27, 2015
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
Frymaster Dean... • Answered on Jul 30, 2014
venting is bad ---- soot build up - obstructions---------clean your unit
Frymaster Dean... • Answered on Mar 05, 2014
Frymaster Dean H22 Deep Fryer Logo
5 questions posted
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Frymaster Dean Kitchen Appliances - Others
Most Popular Question
frymaster fryer keeps calling help
  • Kitchen Appliances - Others
