20 Most Recent Frymaster Dean SR42G Deep Fryer Questions & Answers
If you are leaking oil by one of the burner tubes you can replace the tank or get a new fryer. new tanks usually cost around 400 plus installation. Usually better to replace the fryer.
Tom
Frymaster Dean... | Answered on Mar 07, 2019
I recommend that you get in touch with the company. Or the 1 800 number in the instruction handbook. Or Google by the name of the company. They may correct the problem.
Frymaster Dean... | Answered on Sep 21, 2017
you may check your solinoid if is properly supplied. if equiped with other safety limiter have it checked for example. drain swithces hi limit thermostat float switch some of this may not work properly.
Frymaster Dean... | Answered on Jun 14, 2016
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Frymaster Dean... | Answered on Aug 29, 2015
There is no repair to fix the leaking gas valve other than to replace the gas valve with a brand new one.
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
There is no reset switch. If there is a problem, a repair must be made to make the deep fryer work properly again.
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
Frymaster Dean... | Answered on Jun 11, 2014
Hi there.
Check the gas pressure, it must be standard as required on unit,s nameplate, low gas pressure can cause this problem.
Check and clean also the burners as needed.
Regards.
Frymaster Dean... | Answered on Dec 04, 2013
Either the thermostat or the gas valve has failed. Locate and disconnect one of the wires going to the thermostat, if unit continues to heat the gas valve has failed, if not, the thermostat is likely stuck closed (on).
Frymaster Dean... | Answered on Apr 29, 2013
Hi there.
Your maxitrol regulator specification is correct for natural gas use, the pressusre setting may be in minimum (3"wc) that's why the fryer does not fire-up or it may also be clogged.
Check also if the spring is sitting properly on top of the plunger.
Regards.
Frymaster Dean... | Answered on Jul 12, 2012
Frymaster Dean SR42G Deep Fryer Logo
61 questions posted
Top Frymaster Dean Kitchen Appliances - Others Experts
Paul Carew
Lawrence Oravetz
Dennis Boxerman
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Frymaster Dean Kitchen Appliances - Others
Most Popular Question
pilot knob turn turn off still in pilot
  • Kitchen Appliances - Others
