I have a Dremel 300, it turns on, gets power, makes noise but it doesn't spin. Theres even some smoke when turned on too long. What could be the problem?
SOURCE: Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Sorry for the faulty title. I also want to add that the brushes are 8mm long.
