? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Hi!
you can get to the drip pan removing the base grill in front of the unit. There is no need to empty the tray, since the water that drips into it is consumed by the evaporator. Some drip pans are even fastened by screws and can't be readily removed.
Good Luck!! Don't forget to rate this post!!
if the drip pan is not cracked or overflowing then it could be that the drain tube that goes to the pan is clogged.
a good thorough cleaning of the freezer should help.
also pour a little hot water in the back of the freezer (i take the refrigerator outside and blast it with a hose, but thats just me), this will hopefully melt any ice buildup that may be causing the problem.
the tube sometimes runs on the outside of the refrigerator along the back.
either way the tube goes from the bottom of the freezer to the drip pan.
