SOURCE: Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
SOURCE: Dacor rsd30 celsius to farenheit conversion
Choose the Convection Bake Mode on your controller and select a temperature of 500 degrees or higher. Press and hold Convection Bake for 3-4 seconds and "F" or "C" will appear in red in the display. Using your up/down keys, toggle from "F" to "C", or "C" to "F" depending on your choice. If you hare not using your product, turn it off by pressing Cancel/Secure
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
SOURCE: need instructions for oven cleaning
Go to the dacor website. they can get the manuals for you.
