The water level sensor is disconnected but probably bad and needs to be replaced. This is possible to be done by you but I like when they do it, any thing happens you have there insurance to make repairs and be responsible for property damage.
Testimonial: "Hi, thanks, but I've tested sensor with multimeter and it seems to switch ok. I've even manually blown into it, hear it click, but water doesn't stop. Not sure what else it could be."
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
SOURCE: indesit d41 dishwasher overfilling, pressure
possible faulty pressure switch or a faulty drain pump
Testimonial: "cheers"
