D-Link DIR-300 Wireless Router Logo
A
Anonymous Posted on Mar 15, 2014
Where is the WPS button on a cannon printer - D-Link DIR-300 Wireless Router
Reetesh Haldonkar
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 75 Answers
  • Posted on Mar 15, 2014
Reetesh Haldonkar
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
75
Questions
0
Helped
8605
Points
87
Wps button for printer are in the printer wifiu setup go to setup menu and serach for wifi routers once u find the router try pressing the wifi button on the router within 30 seconds
Where to find wps pin on canon mx494 printer
Hi Mbali, PIXMA MX494 Wireless Connection SetupSome access points (sometimes referred to as routers or hubs) feature an automatic connection button labelled "WPS" which stands for Wi-Fi Protected Setup.This allows permitted devices such as your PIXMA MX494 to connect to your network without needing to enter a password and it enables a quick and easy method of connecting your devices.This method is by far the easiest way of connecting your PIXMA MX494 so if your access point has a WPS button please select the 'WPS Connection Method' tab below for instructions on connecting using this method.If your router does not support WPS we have provided alternative instructions to get your PIXMA MX494 connected so please select the 'Standard Connection Method' tab below.Back to topWPS Connection Method Standard Connection Method Restore to Factory SettingWPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.Press the [Setup] button (B) on the printer. Use the arrow buttons (C) to select [Device settings] and press the [OK] button. Use the arrow buttons (C) to select [Wireless LAN setup] and press the [OK] button. The printer will now automatically search for access points supporting the WPS feature. The following message will be displayed on the printer's screen "Press WPS button of the wireless router about 5 sec. and press [OK] on this printer" Press and hold the [WPS] button on your access point for approximately 5 seconds, then release. For exact instructions on starting WPS on your access point, please refer to its user guide. Press the [OK] button on the printer within 2 minutes. Once connected, the following screen will appear. Press the [OK] button to complete the setup.
Thanks
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
I need to know how to change the touchpad on cannon printer to be able to enter numbers to put in my internet password although it says passfraze not sure what that is or how to retrieve it
The passphrase is the password your router needs to connect the printer to the router. If your printer has a WPS connection ability, you can push the WPS button on your router and it should complete the connection without the need for any input from you.
Where/what is the WPS button on a CANON MX454 printer
The WPS button is not on the printer. This button would be located on your router itself.
If your router does not have a clearly marked 'WPS' button, please use the CD with your computer to perform the standard wireless installation.........
or try this link...
where is the WPS button
1helpful
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Reconnect my cannon mg3250 printer to wifi
Open the settings menu on the printer. For the network settings enter the connection parameters. If the printer has WPS you can skip the settings and use WPS to connect.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
