20 Most Recent D-Link DIR-300 Wireless Router Questions & Answers
3answers
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
8/28/2018 10:25:38 AM • D-Link DIR-300... • Answered on Aug 28, 2018
I tried to connect to the Dlink N300 with my cell
Hi, Connect a laptop wired to the N300, If you cn go online it aint a router issue Second try going online with a laptop Third check the Signal Type B/G/N Keep it to automatic Disable Router PIN Try Different Security WEP/WPAPSK/TKIP
7/8/2017 9:16:57 AM • D-Link DIR-300... • Answered on Jul 08, 2017
Pppoe
This should be from your internet provider: usually it is a email and a password. Sometimes you must use the login info on your modem Your ISP should be able to supply this info.
1/7/2017 12:11:51 AM • D-Link DIR-300... • Answered on Jan 07, 2017
Error 80710102
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
1/6/2017 9:51:17 PM • D-Link DIR-300... • Answered on Jan 06, 2017
I lost my CD driver
You do not need the disc. Using you browser, login into the router using the default IP 192.168.2.1 unless this has been changed and you should be able to configure your router.
1/6/2017 9:13:10 PM • D-Link DIR-300... • Answered on Jan 06, 2017
2answers
Change language chinese to english
Download English language firmware from D-Link.
3/7/2015 4:52:47 AM • D-Link DIR-300... • Answered on Mar 07, 2015
There has been many saying someone can easily hack in others wireless password, if, so, is there a way to prevent them form doing so?
Reset your wireless router to use 'WPA' or 'WPA2' security. That will prevent "sniffing" of your wireless traffic.
2/2/2015 4:46:30 AM • D-Link DIR-300... • Answered on Feb 02, 2015
2answers
How to restore D-Link DIR-300 router to factory defaults
For resetting up your d-link router password you have to follow these steps.. 1. open your browser and type 192.168.1.0 and type user name and password 2.go to wireless settings . you can also restore d-link router settings . 3. or you may can press the reset botton on the back of your router .for more technical help contact d-link Tech Support .i hope this will help you..thanks
11/26/2014 6:06:26 AM • D-Link DIR-300... • Answered on Nov 26, 2014
I forget my dlink password
Type your router's IP address -192.168.0.1- into your Web browser. At the login screen, select "Admin" from the drop down menu and enter your admin password. Once you access the Web configuration screen, click "Setup" in the top menu. Select the "Wireless Settings" link on the left-hand side. From there, click on the "Manual Wireless Connection Setup" button. Scroll down to the field representing my "Pre-Shared Key". If you don't see it, select a security mode from the dropdown menu at the bottom of the screen first. Type in a new password.
8/14/2014 1:12:44 PM • D-Link DIR-300... • Answered on Aug 14, 2014
Download cd driver
Google it out.. Try the advanced search.. Or you can use this intitle:index.of DIR- 300 Wireless router driver Jus type it like that
8/11/2014 12:03:44 AM • D-Link DIR-300... • Answered on Aug 11, 2014
2answers
How do I reboot my
remote reboot: 1) login into router 2) http://$address/sys_cfg_valid.xgi?&exeshell=submit%20REBOOT where $address is IP address:port of your router
3/19/2014 10:52:32 AM • D-Link DIR-300... • Answered on Mar 19, 2014
Where is the WPS button on a cannon printer
wps button for printer are in the printer wifiu setup go to setup menu and serach for wifi routers once u find the router try pressing the wifi button on the router within 30 seconds
3/15/2014 11:01:24 AM • D-Link DIR-300... • Answered on Mar 15, 2014
0answers
Cts auto mode is greyed !
u can reset your router to factory settings and update to the latest firmware and after that u must redo your settings that u hat in the router
11/24/2013 8:52:44 AM • D-Link DIR-300... • Answered on Nov 24, 2013
Hi. My device is transmitting internet to some devices (phones) but not others. How can I solve this problem?
Try deleting the wireless associations on the devices which have the problems, and then re-connect the device to the router. This should solve your problem.
10/30/2013 2:51:20 PM • D-Link DIR-300... • Answered on Oct 30, 2013
Disable enable upnp
Login to the router on its default IP address (sticker on the bottom) - there's an option in the settings to disable uPnP - though unless you know what you're doing, I'd recommend leaving it on.
10/30/2013 2:47:56 PM • D-Link DIR-300... • Answered on Oct 30, 2013
How do i update the firmware on my Dlink DIR-300
DLink.com, go there. Support, device name, read instructions, download firmware, flash device.
10/24/2013 4:24:38 PM • D-Link DIR-300... • Answered on Oct 24, 2013
I tried to port forward for game ranger but it
Portforward.com has a great reference for most routers including yours. Verify what you did matches the instructions on this site. PortForward.com instructions on how to configure DLink DIR 300http://portforward.com/english/routers/port_forwarding/Dlink/DIR-300/GameRanger.htmIf you still cannot connect, verify GameRanger is allowed through your firewall. If you are using the Windows Firewall, temporarily disable it and see if you can now connect and host a game.Windows 7 - how to disable Windows Firewallhttp://windows.microsoft.com/en-us/windows/turn-windows-firewall-on-off#turn-windows-firewall-on-off=windows-7 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/daniel_9df0c6dab34f0108
10/3/2013 7:36:11 PM • D-Link DIR-300... • Answered on Oct 03, 2013
D-Link DIR-300 Wireless Router Logo
235 questions posted
Top D-Link Computers & Internet Experts
Mike
Donivan Wise
Mehandi Husain ...
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
install wireless g router without cd
  • Computers & Internet
