Hotpoint BWM12 Front Load Washer Logo
a
andy clarke Posted on Feb 27, 2014
Hi, I have a Hotpoint wm53w first edition 1200 and the door light does not come on when the door is shut. When I switch it on and set a programme, the amchine sometimes does not start, the door light
Hi, When I switch on the machine, set a programme and shut the door, the door light does not come on, the machine does not always start and I can still open the door. Is this a problem with the latch? Many thanks for your help
Hugh Burgess
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 07, 2014
 Hugh Burgess
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
4322
Points
46
Generally the problem lies with a faulty door interlock switch rather than a programmer fault. These are can be purchased easily but don't be fooled into buying cheap alternatives, and if you are a competant diy person no problem to fit.
5 Related Answers
gittos73
peter gittos
  • 247 Answers
  • Posted on Aug 23, 2007
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
equigs
Eamonn Quigley
  • 3 Answers
  • Posted on Oct 27, 2007
SOURCE: Hotpoint Aquarius WMA34
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Anonymous
  • 1314 Answers
  • Posted on Mar 02, 2008
SOURCE: My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Anonymous
  • 8 Answers
  • Posted on Jul 30, 2008
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Anonymous
  • 3 Answers
  • Posted on Oct 23, 2008
SOURCE: hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Zwh6160p set programme,start/pause light flashes, when pressed machine doesn't start, door does not lock either
Is the door shutting at all or is it just not clicking shut , there is a pressure switch / electronic switch on the door catch mounted on the machine main body which prevents machine running if the door is not shut correctly.
1helpful
Programme settings hotpoint aquarius1200
download your instr.manual from www.fitness.manualsonline.com ro www.retrevo.com for free and proceed with the details.
God bless you
I got a Hotpoint Aquarius Extra Washer Dryer WD64 GB 1200, it worked before and suddenly did not work yesterday, when i supply the power and close the door properly and start the programme, the light is...
most common reason for what you are describing is a faulty door lock part no. 1602390.
easily fitted by undoing door seal retainer, removing two screws holding on door lock and then just change over wire for wire.(only 3 wires).
this should get you going
1helpful
Wmf720 hotpoint washing machine,after loading the washer and shutting the door,i switch on the machine it doesn't start the programme.....what is happening is the word door is flashing on the screen and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
Good luck,
John C
4helpful
3answers
Hotpoint first edition washing machine door will not open after completing its full cycle
hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
1helpful
Door of washing machine will not open.
Some times, you have to really pull hard to open the door
If no joy, then you have a faulty door lock.
To replace. remove door seal at front, thius will give you access to the door lock.
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Hotpoint aquarius
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
