Microwave Ovens Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint Over the Range Microwave is LOUD
The spinning glass plate move very slowly and is extremely loud. We just moved in to a new house and the microwave looks pretty new.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 06, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737874
Points
36075
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
My JEM31 microwave stopped working and makes a loud groaning noise. Is it worth repairing?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Loud sound is coing while operating microwave , but grill is working fine , what is problem ?
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Microwave runs with a loud hum, turntable works, but food doesn't get hot at all!
Hope that helps.
My microwave was making a popping sound. then while i was nuking some popcorn, i heard a loud bang. when i opened the microwave, i saw that the glass turntable plate on the inside had split into two...
What usually happens to make the plate break or shatter is heat build up in one place, caused by spillage of food stuffs that have "welded" themselves to the plate or a scratch on the plate allowing water to enter and when it gets hot explodes the plate.
There, from what you have explained and the information you have supplied, no reason to doubt the machine. A new plate and it should work again with no problem.
Hope that puts your mind at rest.
1helpful
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
1helpful
2answers
No power
I have had all the same problems as you! I fixed it myself for less than $3. Go to home depot buy a CERAMIC fuse for microwaves its in a yellow and black package, take off the back of your microwave and replace the fuse! anyone who tells you that you cant use a ceramic fuse is full of themselves so dont listen to them.
When a fuse even starts to go bad, even though it looks intact: it can make your appliances do strange things. I changed the junk glass fuse with a ceramic one and the microwave worked like it was new out of the box. Give it a try, dont scrap your microwave.
1helpful
Microwave turntable is loud and clunky sounding.
If the unit is brand new as you say then it is covered under the warranty and the 800# for Bosch is in your paperwork that came with it.
It sounds like the glass platen (turntable) hub is either binding or else the drive mechanism itself either has a bad tooth on the main gear or tooth wheel. Some may still use a chain type drive mechanism as well.
If you call that 800 number - the customer service dept there will advise you as to what needs to happen next. It's possible they will either replace or repair at their expense.
Who installed the unit?
Let me know?
Best regards,
Frank
2helpful
3answers
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
2answers
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
No Power at all after loud short buzzing sound
sounds Like an electrical fault in the Micro, Sorry but this is broken.... If this is within warranty (do check as some warrantys are for 3 yrs or more) get the manufacturer to replace/repair it for free. you could get it serviced, but it is probably cheaper to buy a new one.
Top Hotpoint Microwave Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
