20 Most Recent Kenmore 66469 / 66462 / 66464 Microwave Oven Questions & Answers
2answers
On the right side of microwave, the inside of the
Hi, Sorry to tell you but Dont use this again you need to buy a new one or second hand one. Please leave me feed back: Malcolm Campbell, Thanks.
12/4/2017 8:12:47 PM • Kenmore 66469 /... • Answered on Dec 04, 2017
Microwave is locked up
Most microwave ovens are like computers, they lock up and ocassionally need to be "re-booted", or re-powered. 1. Simply unplug the oven, then wait about 10 seconds, plug it back, and check to see if has unlocked itself. If not, continually press the clear or reset button. If that doesn't help, you'll have to get the model number and manufacturer from the label inside the microwave oven.
5/12/2014 3:58:38 AM • Kenmore 66469 /... • Answered on May 12, 2014
How to remove Kenmore Quicktouch micro hood
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet While supporting the unit from below, remove screws. The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it. The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
5/4/2014 10:33:21 PM • Kenmore 66469 /... • Answered on May 04, 2014
0answers
0answers
Microwave is locked
Door switch
11/18/2013 12:02:01 PM • Kenmore 66469 /... • Answered on Nov 18, 2013
Power 100 code
you must try this:God bless youIf you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board.
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
11/14/2013 12:35:04 PM • Kenmore 66469 /... • Answered on Nov 14, 2013
My 7year old kenmore microwave
ther is a high voltage generator to generate enough power to the magnetron to produce microwaves, it was probably ARCHING voltage to the body of the oven due to a faulty insulator and the paint caught on fire... as for using it well DON'T it is not safe, and will cost more to repare than a new one
Sorry!
5/22/2012 5:09:13 PM • Kenmore 66469 /... • Answered on May 22, 2012
Is it possible to check the magnetron
The magnetron looks like the below image3_7_2012_1_51_55_pm.jpgtesting is not easy as it's a high voltage component and can be dangerous to work around.Here is a link for a page with some very helpful information about testing magnetrons.LINK:
3/7/2012 1:54:54 PM • Kenmore 66469 /... • Answered on Mar 07, 2012
Turn table turns some of the time
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Walesarumi
9/29/2011 5:53:28 PM • Kenmore 66469 /... • Answered on Sep 29, 2011
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
Popular Tags
68 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
microwave just stopped working working
  • Microwave Ovens
