SOURCE: 17" Monitor keeps going black
Hi Rahni, It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
SOURCE: rear projection tv picture problem
I have a sony kp-48s65 projection tv. I have three lamps in back a red a green and a blue. when turned on the sound always works
timer standby light blinks steady at 1 pace Once in a while the picture will just come on and work fine it may work for 1 hour or 10h min then the picture goes out . What can i do. People say lamps but when the picture is on and working the three lights behind work fine . its like whatever powers the lights isnt working
Unplugging and plugging back in and waiting usually brings it back on. For so long . When it is on the screen I can see hard bright green and red the picture is really too red its ok but its hue is off or something Tv in good shape what do i do?
tv consumer
SOURCE: Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
SOURCE: Screen shrinks monentarily then zooms in untill screen is blank, then turns off.
I had a similiar issue that caused all my Microsoft applications to zoom out to 500%. It also caused PDF documents to shrink and go the the last page. The issue was caused by the Intellatype software that came with my ergonomic keyboard. The issue was resolved by disabling the zoom feature of the sofware on the zoom tab.
