Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
I have a Sony Wega rear projection 55 inch LCD HDTV. The TV turns on and there is picture and sound for about 30 seconds, then the screen goes blank (no picture or sound) and then comes back on about 30 seconds later, then repeats over and over. The green power light stays on the entire time (even when no sound or picture). If I power off the TV during the period where the screen is blank and no sound and then power it back on, there is a red blinking light where the power light is. It blinks 5 times, pauses, and then repeats. I am then able to turn the TV back on, but the same thing recurs: picture and sound for 30 seconds, then I lose both for 30 seconds, then they come back, etc.
I turned down the picture level on the menu screen and it stopped immediately also changed the picture mode to pro
Posted on Dec 03, 2009
HelloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
shaun
Posted on Oct 25, 2009
SOURCE: Sony Grand WEGA KDF 55 in. Rear Projection HDTV Television
usually is the lamp
Posted on Apr 06, 2008
SOURCE: rca 56" rear projection hdtv will not come on
Ck capacitor cp150 2200uf 16v. there is 2 other caps also if this one is bad,(2) 220uf 35v.(3) caps all together.
Posted on Dec 19, 2008
If you have not done it before I would recommend changing the entire assembly. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix this and where to get the parts. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 05, 2010
SOURCE: Sony grand wega sxrd 60'
3 times red light blink indicates that lamp cover is not fixed properly. This can happen if you took out lamp from tv or replaced it. Lamp cover is plastic cover that need to be removed from tv cabinet to access lto lamp.
Make sure lamp cover is back in its position securely and turn tv On.
Thanks.
Posted on Oct 15, 2010
Aug 23, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
May 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Feb 08, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Mar 17, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
May 18, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
How do I do these things? I don't know what the C board is.
