Sharp AR-5316 Advanced Digital Imager Copier Logo
s
samuel peter Posted on Jan 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Showing triangular red signal and refusing to accept the command photocopy
san3409jl
Level 2:
Habit-Forming:
  • Sharp Expert 190 Answers
  • Posted on Jun 27, 2014
san3409jl
Sharp Expert
Level 2:
Habit-Forming:
Answers
190
Questions
Helped
53256
Points
235
Sharp AR5620V PHOTOCOPY machine triangular red light and display shows that 2 and for comand
toner supply abnormality toner bottle improperly set or ATC sensor abnoromality
I don't have s stanadard TV set (CRT) with pre-digital tuner. I have a Sony PVM-2950 (2950Q) CRT monitor (no TV signal tuner, dumb tube). It accepts external signal feed. Today, the red...
Hello. You might try to re solder the power supply and deflection area, Also the common problems of this TV are the capacitors that lose value. But I think you have loose connections on the card. Good luck, if you have any questions, I'm here to help you with more details. thanks
2helpful
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
2helpful
2answers
Please .. my Photocopier sudunly stop and find
My Sharp is a different model but my reset is:
Hit:
Clear (then)
Auto (then)
Clear (then)
Auto (then)
14 THEN
Start
It resets itself.
2helpful
2answers
There is a red and green led flashing, and the keyboard doesnt accept any typing commands
This means it's lost its Bluetooth signal. Re-run the BT setup and you'll be fine
17helpful
5answers
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
