GE JGBP33 Gas Kitchen Range Logo
A
Anonymous Posted on Jan 29, 2014
Jgbp33beh5bb igniter - GE JGBP33 Gas Kitchen Range
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
3answers
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
1helpful
Model JGBP33BEH5BB cook top burners all light but the oven will not. verified that the gas shut off vavle is on. What would be the next thing to check?
alot of these units have whats called hot surface ignitors or bake/broil ignitors on them... do you have a broil on oven? if so check it put oven on broil and see if upper portion of oven gets hot... if so then you will have to gain access to the bake ignitor.. usually can be done by opening door to oven and removing shelves and the bottom panel of oven inside can be removed usually with 2 screws in back...if you dont have this access panel you can gain access from the lower drawer... once you get into compartment there is a heat shield that can be removed and you will see the ignitor ... pull wires carefully out of rear of unit and there will be 2 porcelein wire nuts make sure you have unit unplugged while doing this, once you get these out remove wire nutts and plug in with a volt meter turn unit to bake and see if your getting 110-125 volts to ignitor wires if you are but did not see it glowing before then you have a bad ignitor.... can be ordered from several online sites and or appliance servicers and fairly easy to replalce... www.sears.com try them wish you luck...
1helpful
How do i change the coil
Ignition Coil Removal
  1. Disconnect fuel charging wiring connectors from ignition coil (12029) and radio ignition interference capacitor (18801) .
  1. Disconnect ignition wires by squeezing locking tabs and twisting while pulling upward. e941a97.gif
  2. Remove four ignition coil retaining screws and remove ignition coil and radio ignition interference capacitor . Save radio ignition interference capacitor for installation with ignition coil .
Installation
  1. Position ignition coil and radio ignition interference capacitor to ignition coil mounting bracket.
  1. Install retaining screws and tighten to 4.5-7.0 Nm (40-61 lb-in).
  1. Apply Silicone Dielectric Compound D7AZ-19A331-A (Motorcraft WA-10) or equivalent meeting Ford specification ESE-M1C171-A to all ignition wire boots.
  1. Install each ignition wire connector to the proper terminal on the ignition coil . Make sure boots are fully seated.
  1. Connect fuel charging wiring (9D930) to the ignition coil and radio ignition interference capacitor .
3helpful
2answers
I own a GE JGBP33BEH5BB and the oven doesn't get hot enough. I've changed the sensor with one from a JGBP30BEA1WH that was working fine when it was removed. (replacements for both are the same part number...
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
2helpful
2answers
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. Remove the engine appearance cover.
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
1helpful
1991 Dodge Spirit ignition problem
The "SPRING-BACK" Action is Originated in the Ignition Switch itself (THE ELECTRICAL SWITCH) I think that is where you should Look. On these models, the ignition lock and ignition switch are removed as an assembly. Refer to IGNITION LOCK .
Disable airbag, refer to Air Bags and Seat Belts/Air Bags (Supplemental Restraint Systems)/Service and Repair . After procedure has been completed, rearm airbag system.
  1. Disconnect battery ground cable.
  2. Remove tilt lever.
  3. Remove three Torx column cover attaching screws, then the upper and lower column covers.
  4. Using tamper proof Torx bit tool No. 440-TX20H or equivalent, remove three ignition switch mounting screws.
  5. Carefully pull switch away from column. Release two connector locks on seven terminal wiring connector, then disconnect from ignition switch.
  6. Release connector lock on four terminal connector, then disconnect from ignition switch.
  7. Remove ignition lock from ignition switch as follows:
    1. With key inserted and switch in Lock position, use a small screwdriver to depress ignition lock retaining pin flush with lock cylinder surface.
    2. Rotate key clockwise to Off position. Ignition lock should now be unseated from ignition switch assembly. Do not attempt to remove ignition lock at this time.
    3. With ignition lock in unseated position (lock bezel approximately 1/8 inch above halo light ring), rotate key counterclockwise to Lock position, then remove key.
    4. Remove ignition lock from ignition switch.
  1. Reverse procedure to install, noting the following:
    1. Connect two wiring connectors to ignition switch. Ensure switch locking tabs are fully seated in connectors.
    2. Install ignition switch on steering column.
    3. On column shift models, shift lever must be in P position and park lock dowel pin on ignition switch assembly must engage with column park lock slider linkage.
    4. On all models, verify ignition switch is in Lock position (flag parallel with ignition switch terminals).
    5. Apply a dab of suitable grease to flag and pin, then position park lock link and slider to mid-travel.
    6. Position ignition switch against lock housing face. Ensure pin is inserted into park link contour slot.
    7. Install ignition switch retaining screws and torque to 12-22 lb-in .
    8. With ignition lock and switch in Lock position, insert ignition lock into ignition switch until it bottoms.
    9. Insert key, then while carefully pushing ignition lock toward ignition switch, turn key clockwise to Run position.
    10. Check for proper operation on ignition switch in all positions.
FOR PICTURES EMAIL ME AT MY NICKNAME HERE ON FIXYA @AOL.COM
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
