303-07A: Engine Ignition — 3.0L (4V)
2001 Lincoln LS Workshop Manual
DESCRIPTION AND OPERATION
Engine Ignition
The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L
Engine Ignition
v-8
REMOVAL AND INSTALLATION
Ignition Coil
Removal
how do i put a coil in a 2001 jaguar s type - a1d93dd.gif"/uploads/images/a1d93dd.gif" alt="a1d93dd.gif" class="h_mi" />
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V)
Ignition Coil
Removal
please rate as fixed if this helps.
What is the location of the number six coil in 2001 lincoln ls-passenger or driver side?
SOURCE: How to put A/C refridgerant into a 2001 Jaguar s
This job requries special tools and training. Have a shop do this job for you and avoid personal injury exposure.
SOURCE: 2001 Jaguar S Type that has a #6 cylinder misfire
The oil may be causing the misfire,you will need to replace the valve cover gasket and sparkplug tube seals, the oil leaks in from the tube seals,also make sure to clean hole out after the repair and make sure the coil is still good, you may have to replace the coil boot if its soaked with oil,
what engine? V6, V8?
