Ariston LSE 620
SOURCE: CDA CI532 - Water not emptying
depending on exact version either blocked sump hose or blocked filter Regards Advisor
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
SOURCE: Water Does Not Drain
You may need to Clean out the pump catch to do this you need to remove the drain pump access cover, insert a pointed object (or tool) into the hole, Bottom right front of the unit push in to release the latch and rotate the cover clockwise.
you will need to clean this out use a shop vac to remove the water in the unit or have plenty towels handy
AS far as the fault code
E:04=Er:04washing=Door control broken
Cause=Faulty Triac or control module
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
SOURCE: WATER IS NOT DRAINING
Most likely the pump has failed or is blocked or jammed. Coins and buttons become trapped in the impeller. Suggest you check the pump drain inspection point - there is always one somewhere at the bottom of the machine. See if you can rotate the pump motor - ISOLATE THE POWER FIRST!
