20 Most Recent Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher Questions & Answers
How do in reset pressure switch on hotpoint fdd914
My Hotpoint Ultima FDD914 has had the A5 error code appearing at the beginning of the wash cycle for over a year. The error has got worse, appearing again at the end and most recently half way through. My solution has been to repeatedly start the cycle and run a rinse wash at the end. Not very practical to the point hand washing dishes is the preferred option. But now the problem is fixed! The culprit is the pressure switch. I found video explaining how to change it. The video is called how to change a pressure switch on a dishwasher and is by yourspares. i had difficulty getting the side panel off the dishwasher. Two screws at front and two at back were fine but there was a sneaky one hidden behind the plastic front base plate. Only had to use a Philips screwdriver and a small flathead to prise the panel from the clips. And I didn't remove the panel completely, just pulled it up enough to find the switch under the insulation. I put the dishwasher on its side (unplugged from wall before starting) I removed the switch as shown in the video, detached it from the hose, blew into the hose and the switch (as suggested by someone) put it all back together and rather surprisingly the dishwasher now works! If the error returns I'll buy a new switch and replace it as shown in the video but for now it's goodbye to the dreaded A5 error.
6/24/2018 9:47:50 AM • Hotpoint-Ariston... • Answered on Jun 24, 2018
0answers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced. Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced. Enter your model number to see parts for your dishwasher.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced. Enter your model number to see parts for your dishwasher.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door. Enter your model number to see parts for your dishwasher.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced. Enter your model number to see parts for your dishwasher.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced. Enter your model number to see parts for your dishwasher.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly. God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
3/28/2014 4:25:12 AM • Hotpoint-Ariston... • Answered on Mar 28, 2014
0answers
0answers
0answers
Troubleshooting
Dispenser Lever
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary. 6717a822-d7e1-4c2e-a0bd-87fdb1bce189.jpg
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly. Gd bless you
5/24/2013 7:14:30 PM • Hotpoint-Ariston... • Answered on May 24, 2013
Fdd914 dishwasher error code
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
9/4/2012 4:32:54 PM • Hotpoint-Ariston... • Answered on Sep 04, 2012
0answers
Fll8214
Be the first to answer 4/30/2012 9:17:00 PM • Hotpoint-Ariston... • Posted on Apr 30, 2012Be the first to answer
0answers
Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher Logo
17 questions posted
Top Hotpoint-Ariston Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint-Ariston Dishwashers
Most Popular Question
troubleshooting
  • Dishwashers
