Have made sure that the filter cover is closed tightly and the lamp cover is closed tightly and the switches to both of these doors are working properly. Power goes all the way through the fuse, so the fuse is good. The projector jus will not turn on
SOURCE: Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
SOURCE: Projector turns off after 30 seconds.
I had the same problem I replaced the motor/lense cover unit at the cost of $AU140.00 and that fixed it.
Leckie
SOURCE: Lamp Cover will not close fully
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
SOURCE: Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
