It's a common issue. But you don't need to worry about it. There are several methods to reset password on iPhone. Just check below steps.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
If this methods won't work, check this guide. How to Reset Password on iPhone
SOURCE: how do i reset my iphone 4 if i forgot the password
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
