20 Most Recent Apple iPhone4 4G iPhone 4 Questions & Answers
H2o wireless puk code
What is my puk code
10/18/2022 1:29:49 PM • Apple iPhone4 4G... • Answered on Oct 18, 2022
3answers
How do I get purchased ringtones back onto iphone
Have not tried ringtones myself; but in every other case, if you go to install something a second time, it will not be charged. Works for apps, books, music, etc. Just use your apple id.
3/22/2022 8:50:39 PM • Apple iPhone4 4G... • Answered on Mar 22, 2022
2answers
Changing ring tones
first go to the song second click on set a list will be shown third click on caller ringtone after that you will assign song to individual
8/16/2021 6:04:46 AM • Apple iPhone4 4G... • Answered on Aug 16, 2021
4answers
How can I make my iPhone4 go faster?
http://www.businessinsider.com/how-to-make-your-iphone-run-faster-2014-7
8/2/2021 7:36:24 AM • Apple iPhone4 4G... • Answered on Aug 02, 2021
3answers
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.Second I would check to make sure the battery is actually charging.Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
7/6/2021 6:48:09 AM • Apple iPhone4 4G... • Answered on Jul 06, 2021
2answers
Iphone 4 battery
Hi,If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.1. Decrease the screen brightness of your phone.2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )4. Turn off bluetooth.5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
6/22/2021 4:05:30 AM • Apple iPhone4 4G... • Answered on Jun 22, 2021
5answers
How do i completely remove contacts from my iphone?
There is no mass method for deleting contacts that are already registered on a phone. Each contact will have to be individually deleted or edited to record details of your contact. The process to edit or delete a contact individually is exactly the same as follows: Open your phone Icon Open contacts Select an individual contact Click Edit Modify the details as required and touch Done or Scroll to the bottom of the contact list and Select Delete Contact You will be prompted to Delete Contact or Cancel Select Delete Contact The contact will be removed. Repeat the process for Editing or Deleting each contact on your list.
6/9/2021 5:50:44 AM • Apple iPhone4 4G... • Answered on Jun 09, 2021
2answers
How do i reset my iphone 4 back to factory reset
Well, so long as you have access to the computer that you sync the phone with then this isn't too hard. What you need to do is hook the phone up to that computer that you sync the phone with to back it up for photos, contacts, data, etc... then press and hold both the home and power buttons at the same time, the display will shut off and the device will begin to boot, when you see the apple logo on the screen release the power button, but keep holding the home button for another 5-10 seconds. iTunes will then pop up a dialoge box that it has detected a iPhone in reset mode, hit the "ok" button and it may tell you that you need to download the latest version of iPhone software to update the phone, allow it to do so (usually takes about 15 minutes or so, depend and upon your connection speed with your ISP), after it does that it should wipe the phone and reinstall iOS and you should be good to go. If you have never synced it with a computer it could be a lot more difficult as you may have an iCloud lock on the device, which isn't so bad if you know your iCloud password, but if you don't, can still be reset, but can be more complicated and time consuming, but hopefully you don't have to go there. if you found this to be helpful please up vote this answer, and if you have any additional questions or issues please respond with them, I will do my best to try and assist. Also plesae let us know if this works for you and your results. Good luck!
1/19/2021 3:16:19 AM • Apple iPhone4 4G... • Answered on Jan 19, 2021
2answers
Every thing works on my iPhone but they can,t hear me when i call someone
Is your phone cover coverng up your microphone???
11/10/2020 10:27:11 AM • Apple iPhone4 4G... • Answered on Nov 10, 2020
2answers
How to unlock apple iphone 4 and use any other carriers sim card. thank you very much!
Unlock your apple iphone 4 and use any other carriers sim card To unlock your apple iphone to use any sim card, you need to get the unlocked confirmation from apple by using any unlock code service provider.After getting the unlock confirmation you need to use i-tune to unlock it here is the direct link of service provider to get the unlocked confirmation How to unlock iPhone Factory Unlock iPhone After getting the unlock confirmation you need to use i-tune to unlock it as below:- How to Unlock the Apple iPhone 6 after getting the confirmation as Unlocked - -Install the last version of iTunes on your computer. -Make sure your iPhone 6 is updated with the lastest version of iOS. -Switch ON your iPhone 6 with a SIM Card from a non-compatible network. -Connect your iPhone 6 to your computer using the Original USB Cable. -Launch iTunes andwait until iTunes detect your iPhone 6. -Now disconnect your iPhone 6sand reconnect it after 10 seconds. -Your iPhone 6 is now Unlocked! Note:-In the unlikely event that your iPhone 6s is not unlocked, please restore your device following the official guideline from Apple - https://support.apple.com/en-us/HT201252 cell phone unlocking-unlockninga-hibp4n2qmsfg2t2flzwkzxof-4-0.jpg
2/26/2020 4:09:51 PM • Apple iPhone4 4G... • Answered on Feb 26, 2020
2answers
How do i plug in my iphone to my laptop
You need to use the USB cable that came with the iPhone 4. Connect the USB part to your iPhone and insert the USB connector into the USB slot into your laptop.
You need iTunes in order to add music, videos, apps etc to your iPhone 4, you can download this software for free from the Apple website: www.apple.com/itunes/download
Just do the steps above and you'll be fine.
Hope to have been of assistance,
Thanks.
2/13/2020 7:34:21 AM • Apple iPhone4 4G... • Answered on Feb 13, 2020
2answers
Reset apple id
  1. Go to My Apple ID (appleid.apple.com), click "Manage your Apple ID", and sign in.
  2. If you have two-step turned on, you'll be asked to send a verification code to the trusted device associated with your Apple ID.
  3. In the "Apple ID and Primary Email Address section," click Edit.
  4. Enter the email address you want to use, then click Save Changes. Apple will send a verification email to that address.
  5. Open the email from Apple, then click Verify Now in the email.
  6. When the My Apple ID page opens, sign in with your renamed Apple ID.
  7. If you have two-step verification turned on, you'll be asked to send a verification code to the trusted device associated with your Apple ID.
After you see a message indicating that verification is complete, remember to update all of the features and services that you use with your Apple ID.
1/23/2020 9:29:06 PM • Apple iPhone4 4G... • Answered on Jan 23, 2020
I bought a new iphone 4, and having problems changing my voice mail.
Could be a hardware issue
10/11/2019 1:01:19 AM • Apple iPhone4 4G... • Answered on Oct 11, 2019
How to unlock iPhone 4
I'm sure you have forgotten your iPhone password so that need to unlock iPhone. It's a common situation. You can solve this problem by means of iTunes or iCloud. Just follow below steps. -Use iCloud
  • (1). Open and log in iCloud on your laptop or PC that is connected with the iPod touch.
  • (2). Click Find My iPod and let it start to search and connect with your iPod touch APP.
  • (3). When iCloud is connected to the iOS device, its position will be fixed and shown on the map, then click the option at the upper right of Clear iPod and follow the next indication.
-Use recovery mode
  • (1). If iTunes prompts you to enter the password, and you cannot remember it, try to use the recovery mode to unlock iPod touch without password. Given that you are using recovery mode, you are not able to backup before resetting device, which means that you are going to lose all the data on the iPod touch.
  • (2). Close iPod device completely. Hold Power button and slide the Power Slider to close iPod touch.
  • (3). Connect your iPod touch to the computer and use iTunes to enter into recovery mode.
  • (4). Open iTunes and hold Power+Home buttons long before the logo of Apple appears. Then click Recovery Mode.
  • (5). Click Set Up As New iPod Touch. Initialize the settings of your iPod touch and import the backup and restore the data.
For more methods, check: How to Unlock iPod Touch
8/21/2019 6:00:10 AM • Apple iPhone4 4G... • Answered on Aug 21, 2019
4answers
Iphone 4 screen
hi friend,if you have any problem with Phone repair ,please add my whatsapp:+86-18300007189,all the help is free ,and we have high quality IPhone LCD with Lifetime Warranty and we are paypal elite Merchant in China,reply me to know more:) ETtrends The Leading Integrated Service Provider of Mobile Accessories qq??20170704153327-oflh51wbllbmovjiolb1zgb2-3-0.jpg
7/25/2019 6:14:33 AM • Apple iPhone4 4G... • Answered on Jul 25, 2019
3answers
How do I retrieve photos and contacts that "disappeared from my iphone 4?
You can resort to iTunes, iCloud or the 3rd-party program to recover the photos and contacts disappeared from iPhone.
Recover Pictures from iTunes Backup
iTunes is quite common for iOS device users to back up and restore data. It is reliable and useful for you to use. Now let's begin to see how to use this tool to find your disappeared photos back in a jiffy. 1) Insert your iPhone into computer with matched USB cord and then run the latest version of iTunes on your computer. Your device will be detected by iTunes automatically. You need to make sure that the computer you use is the one you have backed up your iPhone data before your photos lost. 2) When you are asked to trust the computer, you need to enter your passcode to continue. 3) After that, you need to click on "iPhone icon> Settings> Summary" to choose the option of "Restore Backup" to tap on. 4) Choose the backup that you have created most recently and then click on "Restore" button to begin to recover iPhone data immediately. Make sure your iPhone is connected to computer during the whole process. The shortcoming of this way is that all your data stored on iPhone will be covered by the backup you restore from iTunes and you are not able to choose the specific photos that you want to get back to iPhone.
recover-pictures-from-itunes-backup-choose-backup-data-6-rxqguaxprphsht5akktphrm1-5-0.jpg
Recover Pictures from iCloud Backup
It is handy for you to recover images from iCloud backup via Apps & Data screen. 1) On your iPhone, you need to click on the Settings app on home screen and then hit on "General > Reset > Erase All Content and Settings". 2) When you see the screen of "Apps & Data", you need to choose the option of "Restore from iCloud Backup" here. 3) Use your Apple ID to log into your iCloud account and then choose the iCloud backup that you want to restore to your iPhone from. 4) Wait until the restore process comes to an end. You need to make sure the Wi-Fi network is stable and connected during the whole procedure. For more details, check: Fixed: Pictures Disappeared from iPhone
5/22/2019 2:45:07 AM • Apple iPhone4 4G... • Answered on May 22, 2019
2answers
Iphone disabled
To unlock Iphone4, there are jail-breaking and unlocking by codes/remote unlocking. As far as i know, jail-breaking iphone's were not unlocked fully. If you update a new software they again get locked and you need to unlock the phone again. There are site which remote unlock iphone's successfully. i will suggest the website TheUnlockArena.com which is doing good service .....you can approach this website.
1/31/2019 9:09:44 AM • Apple iPhone4 4G... • Answered on Jan 31, 2019
2answers
Unock iphone 4
Hi whether you want to unlock your iphone 4 from network lock then visit wickedunlock.com here they help you unlock your iphone using remote unlocking service.
10/22/2018 7:54:13 AM • Apple iPhone4 4G... • Answered on Oct 22, 2018
2answers
How to find blocked incoming blocked calls
block-number-2-goromrtq2rpz3aerkxipchre-5-0.png Go to Settings>>Phone>>Blocked on your iPhone to check out all the blocked numbers. for more details visit: How to Block Numbers on iPhone and Find Blocked Numbers on iPhone
3/26/2018 6:10:54 AM • Apple iPhone4 4G... • Answered on Mar 26, 2018
Apple iPhone4 4G iPhone 4 Logo
694 questions posted
Popular Products
Top Apple Cell Phones Experts
Marvin
Marvin
ADMIN 61k
ADMIN 61k
matt
matt
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Apple Cell Phones
  • Apple Cell Phones
Most Popular Question
trakfone account many hours not used
  • Cell Phones
