Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
A
Anonymous Posted on Jan 15, 2014
Cls1110 charger flashing red
Phone battery charger flashing red led
John L radiodude365
Level 3:
Master:
  • Motorola Master 570 Answers
  • Posted on May 19, 2016
John L radiodude365
Motorola Master
Level 3:
Master:
Answers
570
Questions
0
Helped
209818
Points
1236
Sold hundreds of these: battery may be bad. Contacts on radio or charger may be dirty. I clean these with a pencil eraser and a little rubbing alcohol. Then reinsert, it may take 3+ times. If it still flashes, take the battery out and try to charge it in the back, batt only slot. If it charges there, clean contacts again. Last, get a new battery. They are cheap enough and LiOn batts do not last long in storage, even unused. I recycle mine out every 2 years.
Shaun Baxter
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on May 17, 2016
Shaun Baxter
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
16798
Points
64
RIDGID: 18V 8.0 Ah Rapid MAX charger flashes red and green at the same time. Why is this please?
Question edited for clarity and correct spelling of the maker.
Here is the manual section on the LED Lighting sequence. Both Red and Green flashing is not there. Your charger has a model number on the bottom of it and you didn't supply that, so this may be the wrong charger!
http://powertool.manualsonline.com/manuals/mfg/ridgid/140276002.html?p=5
The question was mentioned on Fixya before.
I have a ridgid rapid twin 18 V charger that flashes red and
Fixya https://www.fixya.com > Forum > Drills > Ridgid
Nov 21, 2019 - Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing.
My charger is flashing red when i place the battery in it - Fixya
Dec 7, 2010
Ridgid temp delay light flashing on charger - Fixya
Sep 2, 2019
My RIDGID Rapid Max Twin 18 volt charger, all it - Fixya
Aug 31, 2019
18v ridged rapid max charger flashes red and green same
Mar 12, 2023
More results from www.fixya.com
Mar 12, 2023 • Drills
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
2answers
Phone wont power up. Red LED flashes once, then four times, pauses, then once, four times...etc...
Try a hard reset, with the phone on remove the battery, wait 1 minute and reset the battery, put on the charger for about 15 - 20 minutes before turning it on again. Hope this helps if not repost.
2helpful
2answers
My Motorola CLS1110 Two way radio has issues charging. I have a 6 station charging station and when I put the walkie on the dock to charge the light just contiues to blink red. I have to continually...
You may have a bad battery, or even dirty battery contacts. A few troubleshooting ideas include:
1) Swap the battery to another known good CLS1110 radio and see if the other radio has the same problem when placed on the charger. If so, you have a bad battery. This type of battery typically lasts approx. 18-24 months before needing replaced.
2) If swapping the battery proves to be successful, check the battery contacts on the affected radio for debris, scum or dirt. Clean the contacts on the charger and the radio with a pencil eraser if needed. (The fact you have to readjust the walkie in the charger indicates you might have problems with the contacts.)
3) Try the battery from the known good radio in the affected radio, if the battery charges correctly, you know the radio is fine. If the charger blinks with the known good battery, then you know you have a radio problem.
Best regards.
3helpful
2answers
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
42helpful
10answers
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 • Cameras
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
3answers
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
