It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
This is an indication of a receiver problem. Two things cause this. The receiver needs to be realigned or you have bad ceramic filters that need to be replaced.
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Your system is getting hot......Clean the dust from the unit with a vacume...not a can of air, Canned air will only push the dirt further into the unit. also you can buy an intercooler for the ps3 nyco makes one that actually forms to the ps3
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
