20 Most Recent Motorola Mag One BPR40 Two Way Radio Questions & Answers
First you check the volume, turn the volume, then you check your speaker. If both are ok then you check QT and DQT. These character must be same.
Motorola Mag One... • Answered on Jul 11, 2016
If this is after programming your radio needs repaired. We see this when some BPR40s are reprogrammed. Take the radio to your local service center or send to a qualified repair center.
Motorola Mag One... • Answered on Dec 17, 2015
Clean the battery contacts with a pencil eraser and be certain the radio is turned off while setting on the charger. If this does not solve the problem, try a different battery in the charger to see if the charger is working properly. If the problem is not the charger, then replace your battery.
This can be a trick. You can slide a small screw driver between the battery and the clip to release the clip. Sometimes you need a third hand. Tapping the bottom of the belt clip on the edge of a counter while slipping the screwdriver in the sweet spot will sometimes help.
Contact Motorola Solutions. Get Support . Mark Motorola Mobility Support
Motorola Mag One... • Answered on Jul 27, 2015
Great question! Clear and easy to understand! The volume and channel switches likely have a metal "O" ring that screws down on the threaded switch and holds the top of the radio to the housing. Remove the knobs, then use a really small flathead screwdriver, insert it into a notch in the "O" ring and unscrew. Be careful and you should be fine. If not, get it to a radio repair shop.
Motorola Mag One... • Answered on Apr 17, 2015
First check your battery pack. A bad or low battery will produce static. Secondly, check your antenna. If it seems to turnaround inside when you hold on to the threads and the outer sheath, you need a new antenna. Beyond this your radio is likely in need of repair. Best regards.
Motorola Mag One... • Answered on Jan 06, 2015
Well there are a few possiblilities: 1 - If the headset is not an OEM part then the wiring or jack may not match or the impedances may be mismatched. 2 - When you say doesn't work you need to be more specific. VOX capable y/n, VOX Working y/n, PTT on head set y/n, etc. 3 - Has the radio phone/mic jacks ever been modified? Good Luck with the testing
Motorola Mag One... • Answered on Nov 09, 2014
Contact Motorola Solutions (http://www.motorolasolutions/support)
Motorola Mag One... • Answered on Jul 31, 2014
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Motorola Mag One... • Answered on Jun 26, 2014
you will need programming cable and programming software
Motorola Mag One... • Answered on Jun 11, 2014
Monitor function and PTT are often either side by side or on the same key. (Upper or lower portion of key). You may be hitting both or the wrong side of the button. Cheers.
Motorola Mag One... • Answered on Apr 22, 2014
That radio is easily programmable for other, or additional frequencies in the same band. I believe (I've been out of the business for a while) you need a special computer interface and software in order to affect a change. I'd contact a Motorola shop. You will also need to be licenced for the new frequency. I hope this helps.
Motorola Mag One... • Answered on Mar 31, 2014
Motorola Mag One BPR40 Two Way Radio Logo
72 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Sheldon Dedek
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
Quickstick Motorola
  • Quickstick Motorola
Most Popular Question
magone bpr40 remove board from metal
  • Radio Communications
