Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
A
Anonymous Posted on Jan 08, 2014
Maintenance codes for dcp-j725dw - Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Brother mfcj825dw. How can I replace paper feed roller?
You can find all the procedures required to change the paper rollers, with detailed images for each step in the service manual for this equipment.
https://www.anyservicemanuals.com/downloads/brother-dcp-j525w-dcp-j725dw-dcp-j925dw-mfc-j280w-mfc-j425w-mfc-j430w-mfc-j435w-mfc-j625dw-mfc-j825dw-mfc-j835dw-service-manual-and-parts-list-manual/
Manually clean print head dcp-j725dw
Explore the options on the printer display. Find maintenance and poceed from there. You will have to use menus anyway (on the computer or on the MFC display).
Scan a document into Word
Hello
Notepad uses the file extension ".txt"
You can open this file in Word and then choose "Save As" and change it to the Word format (.doc or .docx).
I would assume the scanning feature is using OCR (optical character recognition) and, after the scan, the default is to save it in a .txt format so it will open in almost any computer.
You can set your computer to use Word to open .TXT files automatically. You would still have to choose the "Save As" and change the format to Word before you can make meaningful editing changes (elaborate fonts, stationary, etc.) as .TXT files have only the most basic formatting available.
Unable to scan ax
the scanner is faulty, replace it.
1helpful
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
5helpful
I cannot print from printer brother DCP-135C with an error message - Clean Unable 46, please assist
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
1helpful
2answers
To get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
Norman Weimar
Norman Weimar
k24674
