After cleaning my ionic pro the red light stays on what to do?
SOURCE: red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
SOURCE: My.Ionic.Pro.doesn't.Blow!!
The red light means the unit needs to be cleaned. A blue light means the unit is working correctly
SOURCE: Ionic air cleaner
take out the insert and clean it real good ... there is a leaver on back of the machine move it up and down about 10 times to clean the strands ...... make sure you clean the 3 steel thin metal strips good let it dry before you put it back in to the machine ..... + i have that same machine - i have 2 cats - it gets dirty quick
pss the poping sound is the machine is telling you it is dirty ... static electric charge
SOURCE: I placed the filters back in , but the clean red
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
