How fast does it normally take to heat up? How old is the urn and is it used regularly? If it is reasonably old it might be worth changing the element anyway depending on the cost. Look inside the urn and check if it needs descaling as that, if it's a really heavy build up, can affect the heating speed.
Try disconnecting the neg battery terminal for about five minutes. if that doesnt work then it will have to be reset by the dealer or try by unhooking positive cable to battery, wait one or 2 minutes then hook cable back up to battery. this should reset it. good-day !!
enter *2767*2878# and wait for a miute , it will turn ff an then turn on itself, wait untill it completely reboots , aftr 2--3 minutes check it -----njoy
Have your Regulator/rectifier checked , and have your ststor checked also . Both are not hard to fix , regulator about 15 mins and ststor about 45 mins .
Go to the OSD menu and select the configuration menu scroll down and select the auto power off selection( in most cases it is preset to power off after ten minutes of inactivity) turn the auto power selection off and there you go!!!!!!!!!!!!!
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things: 1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it. 2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear. 3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
you may have a printer spooler issue. go to start printers. right click on the printer that you are trying to use. the click open. then click on printer. then cancel all jobs and all th ejobs in that box should erase waite about 3-5 minutes and try printing again the first one might take a few miutes to go but after that you should be good. please rate me thanks
